Dizzle223 Posted August 2, 2013 #1 Posted August 2, 2013 So I just had my carbs done at a local shop. Got them back on the bike and noticed the choke lever didn't feel right. Upon closer inspection I saw 2 of the choke valves (enrichment valves) would not move and the other 2 were sticky. I loosened the linkage on the 2 that were not moving and was able to get the bike running but they are still stuck. Was wondering if anyone else has had this problem and what can I do to free these sticking valves. I've posted a picture of the part if that helps.... Thanks! Brian
Peder_y2k Posted August 2, 2013 #2 Posted August 2, 2013 You'll need to examine the brass plunger end, plus the linkage, and, the cable connection for binding. It's possible something was forced and bent, or misaligned. Try a shot of WD40 on the plunger as well. -Pete, in Tacoma Wa USA
greg_in_london Posted August 2, 2013 #3 Posted August 2, 2013 Be careful when you wiggle it - the bent metal lifter arms are not that strong and it is possible to break the end of the plunger where the groove for the lifter is :-(
Dizzle223 Posted August 3, 2013 Author #4 Posted August 3, 2013 Thanks guys... I ended up pulling the carbs and removing each valve. With a little TLC they are working as they should. Happy riding! Brian
