Huggy Posted August 1, 2013 #1 Posted August 1, 2013 OK got the bike running but the turn indicator lights do not work. Now there are a couple wires that come out of the bottom of the reservoir for the rear brake and left front brake. They are a little crispy from the fire. Would that mess up the turn indicator? Everything else electrical looks good. So where do I start and where is the flash for the turn signals? I looked for it under the dash so its not marked the warning unit seems to be the only one that is. So which one is the flasher?
Flyinfool Posted August 1, 2013 #2 Posted August 1, 2013 Those crispy wires should have no effect on the turn signals. The 4 way and turn signals are all the same flasher. So have found it.
Huggy Posted August 2, 2013 Author #3 Posted August 2, 2013 Where is the flasher I know its behind the head light BUT which one is it????
Black wing Posted August 2, 2013 #4 Posted August 2, 2013 its the bog aroung the middle of the relays fairly big, i beleive its box 41r
Huggy Posted August 2, 2013 Author #5 Posted August 2, 2013 OK Black wing thanks for the reply. I'm going to have a look tomorrow for it. I was quite surprised at how well the bike ran since this is the first time it has been started in nearly 11 years! I have a small coolant leak on the pipe that runs from the thermostat to the water pump. Disappointed with that as I had replaced the "O" ring on it. Also a small oil leak underneath on the right side, if you are on the seat, just in front of the collector. Can't see where it is but I'm dropping the exhaust tomorrow to patch a hole in the collector. Exhaust pipe coming out of collector has a hole in it. Looks like someone tried welding the tab on chrome cover on the side of the collector and burned a hole through the pipe. So now that I know it runs I can get down to doing the needed repairs!
