  Condor said:
The two part numbers you need to pick up are:
3AJ-24534-01 SEAL COCK and 3AC-24523-00 VALVE PACKING
There's also a base gasket 4X8-24512-00, but it may not be needed. Check the original first. They should run around $10 bucks total.
This is a good idea, but be careful as piecing it out can become spendy. Know that for less than $10 bucks more than the parts listed above, I bought new washer plates and the new petcock assembly. No plastic parts, now all metal.
  • 3 weeks later...
Hi,
Just found out the hard way about no reserve on my 1996 Royal Star. Just bought it the other day and when the engine started to sputter, I just switched it to reserve.....guess what? So I noticed on the odometer it said 156 miles. So from now on when I see 125 miles, this old sailor will find the nearest gas station. Thanks for all the comments, they really opened my eyes to what is going on.
  Lcranston01 said:
Hi,
I got 170 out of mine (35.4mpg), you're super safe getting fuel at 125.
Hope you stick around and become a contributing member, this place
is a wealth of knowledge, and if you've just gotten your bike, it'll be
the best $12 you spend on it! :cool10:
