Black wing Posted July 29, 2013 #1 Posted July 29, 2013 so ive got a spare frame sitting around and will be moving into my new shop end of the fall so ive been mulling over the difficulties of shoving an 1800 vmax motor into a first gen ( i know drool over the concept). from what i can see in the parts diagrams the new vmax only has one bar in the back with two x braces holding it from the top, and if i could get the engine lined up to have the output shaft fit into the swing arm will the vmax drive shaft reach or require me to machine a custom one? i am also aware they are fuel injected and will require a whole new harness to make the first gen electronics and the vmax ignition to run
syscrusher Posted July 29, 2013 #2 Posted July 29, 2013 After the VMAX 1700 came out I started bugging the GM at my LBS as to whether Yamaha was going to put that engine in a new RSV or something similar and I was told that the VMAX motor was just too costly. A re-envisioned RSV would be more expensive than anyone would ever pay. That being said, there aren't any 1700 VMAX motors on eBay to buy. Also, I have seen some discussion of the frame strength of the VR not being up to the higher torque. The payload rating is less than 400 lbs., indicating a frame that is lightweight. Other wise, maybe I'll buy a kit from you once you have things worked out? :080402gudl_prv:c
cimmer Posted July 30, 2013 #3 Posted July 30, 2013 When I asked about the motor, I was told that it is longer then the venture motors so you might have to lengthen the frame for it to fit. Good luck.. Rick F.
Black wing Posted July 30, 2013 Author #4 Posted July 30, 2013 sounds like its gonna be one hell of a job
k9cottage Posted July 30, 2013 #5 Posted July 30, 2013 maby it would be simpler to put the tank , faring & seat from a 1st gen onto a late model vmax
