Flyinfool Posted July 25, 2013 #1 Posted July 25, 2013 I was out to look at a Bunkhouse camper last night. it is a 93 that has only been used 5 or 6 times. Everything on it looks like new. It even has the added "den" room. It looks to be a great deal asking $1500 and I know he will come down on that. Unfortunately Is is not in the cards for my budget right now. If anyone here is interested let me know, It has not been advertised anywhere yet but will be soon, it is priced to sell. The seller is someone that I know Locally.
Venturous Randy Posted July 25, 2013 #2 Posted July 25, 2013 Sounds good, but if it local to you, it is too far for me. RandyA
CaptainJoe Posted July 25, 2013 #3 Posted July 25, 2013 (edited) How does the nylon look? what size tires 8" or 12" are tires good ? Only 90 miles from rockford?? Hummmmmmmmmmmm.. Edited July 25, 2013 by CaptainJoe
Flyinfool Posted July 25, 2013 Author #4 Posted July 25, 2013 (edited) Nylon looks like new. Tires are 12 inch. Tires look like new. I did not see any cracking on the tires, but they are 20 years old. There is a spare and a 4 way wrench included ...... Actually the trailer is 13 miles south of me, so it is even closer to Rockford. If you were to buy it I could help you get the wiring to match your bike. The trailer has a 6 pin round connector on it but is a 5 wire setup. 6th pin is not used. If anyone is interested let me know quick, he wants to list it on Craig's list to be able to sell before Sturgis. Edited July 25, 2013 by Flyinfool
Flyinfool Posted July 25, 2013 Author #6 Posted July 25, 2013 I don't have any pics, but I probably can get some.
dave_wells Posted July 25, 2013 #7 Posted July 25, 2013 (edited) Post some pictures Check the tires -- replace the if that old I would check the condition of the screens - Mine is an 05 I have a few patches Pack the bearing when you buy it don't think to long if you think it is a good deal Edited July 25, 2013 by dave_wells typo
CaptainJoe Posted July 26, 2013 #9 Posted July 26, 2013 Sold! Just got off the phone with Don. Picking it up Sunday afternoon... Thanks Jeff... I owe you one!
Trader Posted July 26, 2013 #10 Posted July 26, 2013 good on ya! I"d love one of those. Instead, I got one of those "2 sec." tents to go in my HF trailer.
CaptainJoe Posted July 26, 2013 #12 Posted July 26, 2013 Thanks, Thing I'm gonna like about it the most is storing stuff in it, so i can just hook up and go!
Flyinfool Posted July 26, 2013 Author #14 Posted July 26, 2013 I'll make him take pics when he pics it up Sunday.......
CaptainJoe Posted July 26, 2013 #15 Posted July 26, 2013 Yeah yeah I'll take pics...LOL Anyone know if they make a pigtail that goes from the 4 wire on my bike to a 6 wire round on the bunkhouse or is this something odd.??
dacheedah Posted July 26, 2013 #16 Posted July 26, 2013 (edited) On another forum it says the bunkhouse comes with this connector: http://www.etrailer.com/Wiring/Hopkins/37995.html Red = Brakes Brown = Tail lights (running lights) one wire was loose to ground on new set up. White = Ground (screwed to under tongue, on single self tapping screw - I don't like and will double up contact surface area for this and any open to the weather grounds like the side lights with the same self tapping screws). A larger contact electrical connector with paint ground off trailer or second ground. Blue = Accessory plug wire wrapped under Left axle area. I covered mine for spare and wire safety. Green/yellow = Turn signal Yellow= Turn signal Brown/yellow Running lights. isolator or from the to Bunkhouse http://www.rivcoproducts.com/instruc...07_booklet.pdf Black to white -ground Green to Red brakes Orange to - Green/yellow - Left Turn Blue to yellow - right turn lights Brown to brown Running lights Edited July 26, 2013 by dacheedah
Monty Posted July 26, 2013 #17 Posted July 26, 2013 I have both a 4-wire to round & a 5-wire to round, that I use for my truck. Get them at any auto parts store, or maybe Wallyworld. The trailer is 5 wire, so you're gonna need a converter for the bike that goes from 4-5 wire.
Monty Posted July 26, 2013 #18 Posted July 26, 2013 Yep Kevin, when I bought mine, it had that square 5 wire plug on it, and I just cut the plug up so I could wire individually, until I got home.
CaptainJoe Posted July 26, 2013 #19 Posted July 26, 2013 Sounds like Jeff and I are going to be doing some cuttin...
Flyinfool Posted July 26, 2013 Author #20 Posted July 26, 2013 Well this one has a round 6 pin connector. One of the 6 pins is not used. Who knows what a PO did.
Flyinfool Posted July 26, 2013 Author #21 Posted July 26, 2013 Well this one has a round 6 pin connector. One of the 6 pins is not used. Who knows what a PO did. The easy options; 1. We can wire the bike with the mating 6 pin connector. (if any local stores have it in stock) 2. We can rewire the trailer to a 4 wire configuration to match your bike. (this might be fastest option) 3. We can put a flat 5 on both the bike and trailer. The harder option; Rewire everything to whatever other configuration you really want. There is a 4 wire to 6 wire adapter available that will get it close to working right. From what it looks like to me is that it will end up with the amber turn signals on the trailer acting the same as the Brake/turn lights of a 4 wire trailer, and the red lights on the trailer would be running and brake lights. There would be one extra wire to connect on the bike side to pick up the pure brake signal. Tis would at least get him thru the IR and back home to wire everything to his preference.
Monty Posted July 26, 2013 #22 Posted July 26, 2013 Or....you could pick up one of those setups with the plug, full harness & 2 taillights, all wired up. Just plug it in & go. I think the lights are usually magnetic. Tow truck drivers use them a lot & so do people pulling vehicles with an RV. Quick fix. http://shop.advanceautoparts.com/webapp/wcs/stores/servlet/product_magnetic-towing-light-kit-reese_22080531-p?searchTerm=towing+lights
dacheedah Posted July 26, 2013 #23 Posted July 26, 2013 Thats actually not a bad way to go, bought a set years ago to drag a trailer home from deer camp, couple zip ties for loose wire and roll Sent from my iPhone using Tapatalk
Flyinfool Posted July 26, 2013 Author #24 Posted July 26, 2013 Would have to frajicate some kind of a mount for the lights. http://www.harborfreight.com/12-volt-magnetic-towing-light-kit-69626.html I don't think the magnets are strong enough to get a good hold on the fiberglass. But that could have possibilities.
Monty Posted July 26, 2013 #25 Posted July 26, 2013 Mine has a steel chrome bumper on the back, with several running lights in it. Should stick to that.
