Guest tx2sturgis
Take two Seafoams and call me in the morning.
:happy34:
check your tps a motor needs 3 things to run, fuel ,air and a spark at the right time if it isnt getting that it aint goin to run.
I have hit the rev limit many times. You can tell because it starts missing and the oil light flashes. Never hurt anything because the rev limiter worked. These bikes will go another 700 rpm safely so there's nothing you could have done to it unless you had a Dyna installed and it was set above 7300. Check that the airfilters are clean and that the boxes are buttoned up correctly. Both the first and second gens are sensitive to changes in the airflow via a loose fitting or blockage even in small amounts.
I found and ordered the 42S from here. [ame=http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=160808797946&fromMakeTrack=true&ssPageName=VIP:watchlink:top:en]Mr Gasket 42S Electric Fuel Pump | eBay[/ame]
Edited by flalumbee
  wes0778 said:
Have you tried reving it with the choke pulled out? :confused24:
If it is leaning out under high rpm that would certainly fatten it back up, if only for a second or so.
You would know.
If it is starving from weak pump it likely won't make a bit of difference.
If it is electrical the extra fuel would bog it down.
Curious to know if the OP pulled the plugs at least to check them.. I had a similar problem with another bike and it was one of the spark plugs.. basically missing parts of it.. Idled and low powered ok.. but couldn`t make power or speed.. needless to say the engine required a rebuild after that.. ergh (hoping this is not the case for the OP)
It turned out to be clogged air intakes, shop cloth and wad of paper towel I had inadvertently left behind. Thanks for all the input and I'm thankful it was not something serious. Replaced the plugs, as I had fouled them out. Happy to be back on the road again.
All the best to all of you!
