Bert2006 Posted July 23, 2013 #1 Posted July 23, 2013 Hi folks, Been searching site for an hour for what wires to connect to when adding extra brake lights. I am looking to install my Bikevis red bullets and am not sure what wires are what. I also have the modulator that will alow me to use them as running\brake. What color is the brake, ground, etc on the bike. Also looking to tying into the harness under seat. To do so, do i need to remove the passenger seat? If yes how is it done. Thanks in advance for helping me out.
bongobobny Posted July 23, 2013 #2 Posted July 23, 2013 The yellow line is the brake light line. You will find all you need behind the licence plate light, the brown, blue, green and yellow, and black ground inside the chrome piece...
Bert2006 Posted July 23, 2013 Author #3 Posted July 23, 2013 (edited) bongobobny said: The yellow line is the brake light line. You will find all you need behind the licence plate light, the brown, blue, green and yellow, and black ground inside the chrome piece... Thanks bongobobny, But i need to tie to harness under the seat as the lights will be attached to the bottom of the trunk and i do not want wires going down to the license plate. Ok I think I found it in another post, Yellow is brake Blue is running Brown is left turn Green is right turn Black is ground Is that correct? Edited July 23, 2013 by Bert2006
Freebird Posted July 23, 2013 #4 Posted July 23, 2013 Take a look at this thread. It is a write-up I did on installing a isolator for the trailer wiring and outlines all the wires. http://www.venturerider.org/forum/showthread.php?t=503
M61A1MECH Posted July 23, 2013 #5 Posted July 23, 2013 I can make you a plug and play harness that will plug into the harness under the seat so you do not have to cut any wires. Look for me under member vendors on the classified section. That is as long as it is not a GEN 1, but can do for GEN II Royal Star based bikes.
Bert2006 Posted July 23, 2013 Author #6 Posted July 23, 2013 Freebird said: Take a look at this thread. It is a write-up I did on installing a isolator for the trailer wiring and outlines all the wires. http://www.venturerider.org/forum/showthread.php?t=503 Ok that helps confirm the wiring. Only remaining question is how to remove passenger seat? Thanks again for your help.
Bert2006 Posted July 23, 2013 Author #7 Posted July 23, 2013 M61A1MECH said: I can make you a plug and play harness that will plug into the harness under the seat so you do not have to cut any wires. Look for me under member vendors on the classified section. That is as long as it is not a GEN 1, but can do for GEN II Royal Star based bikes. Thanks for the offer but looking at doing this tonight. Should be simple now that I know which wires do what.
Freebird Posted July 23, 2013 #8 Posted July 23, 2013 Passenger seat is easy. First you have to remove the riders seat. Then you will see two bolts that need to be removed to remove the passenger seat.
Bert2006 Posted July 23, 2013 Author #9 Posted July 23, 2013 Freebird said: Passenger seat is easy. First you have to remove the riders seat. Then you will see two bolts that need to be removed to remove the passenger seat. Ok thanks Off to the garage I go to do the install.
bongobobny Posted July 24, 2013 #10 Posted July 24, 2013 Bert2006 said: Thanks bongobobny, But i need to tie to harness under the seat as the lights will be attached to the bottom of the trunk and i do not want wires going down to the license plate. Ok I think I found it in another post, Yellow is brake Blue is running Brown is left turn Green is right turn Black is ground Is that correct? That is correct.
Bert2006 Posted July 24, 2013 Author #11 Posted July 24, 2013 Ok finished the install. Will post pictures tomorrow night. Back of bike looks stock as the lights are so tiny but when they light up wow. Thanks for all the help guy's.
Bert2006 Posted July 24, 2013 Author #12 Posted July 24, 2013 (edited) Here is a piicture of where they are installed with brake lights on. When they are off they practically disappear. Edited March 12, 2016 by Bert2006
dacheedah Posted July 24, 2013 #13 Posted July 24, 2013 M61A1MECH said: I can make you a plug and play harness that will plug into the harness under the seat so you do not have to cut any wires. Look for me under member vendors on the classified section. That is as long as it is not a GEN 1, but can do for GEN II Royal Star based bikes. This is a goood route for adding aftermarket accessories, if one becomes an issue you can simply disconnect and plug back to stock and ride on, oops too late . . .
