Yammer Dan Posted July 21, 2013 #1 Posted July 21, 2013 (edited) About the 6th item down is 3rd gear 92 mph measured at 7500 Rpm's!! Crank close to 9000 Rpm's this would be......:rotfl: Those riding Hardley's can ignore this as it no longer pertains to them..... PerformanceStanding 1/4 mile12.69 sec. @ 103.92 mphEngine rpm @ 60 mph, top gear3313Average fuel consumption rate42.6 mpg (18.1 km/L)Cruising range226 miles (363 km)Load capacity (GVWR less curb weight)417 lbs (189 kg)Maximum speed in gears @ redline(1) 48 (2) 70 (3) 92 (4) 116 (5) 136EngineType Four-stroke, V-four; liquid-cooled with dual chain-driven overhead camshafts; four valves per cylinderBore and stroke76.0 x 66.0mm (2.99 x 2.60 in)Piston displacement1198cc (73.1 cu.in.)HP90Compression ratio10.5:1Carburetion (4) Mikuni 34mm constant-vacuumExhaust systemFour-into-twoIgnitionBattery-powered, inductive, magnetically triggeredAir filtrationPaper element, disposableOil filtrationPaper element, disposableOil CapacityPeriodic oil change 3.7 US qt/3.5L/3.1 Imp qt w/filter replacement 4.0 US qt/3.8L/3.3 Imp qtTransmissionTypeFive-speed, constant-mesh, wet-clutchPrimary drive Spur gear87/49, 1.78Final drive Shaft, with helical bevel gears21/27 x 33/10, 2.57Gear ratios (transmission)(1) 39/15, 2.60 (2) 39/22, 1.77 (3) 31/23, 1.35 (4) 31/29, 107 (5) 29/32, 0.91Gear ratios (overall) (1) 11.88 (2) 8.09 (3) 6.17 (4) 4.89 (5) 4.16 Home ChassisFrame TypeDouble-downtube, full-cradle frame; round-section steel swing armFront SuspensionCenter-axle, air-adjustable fork with 40mm tubes, anti-dive valving and 5.1 in. (130mm) of travelRear Suspension (1) air-adjustable shock absorber, adjustable for rebound dampening, producing 4.2 in. (107mm) of rear-wheel travelWheelbase63.4 in. (1610mm)Rake/Trail28.5 deg /4.9 in. (125mm)Front BrakeHydraulic, dual-disc with dual-piston calipersRear Brakesingle-disc with dual-piston calipersFront WheelCast, 2.15 x 18Rear WheelCast, 3.00 x 16Front Tire120/90 18 65H Dunlop Qualifier F-16Rear Tire140/90 16 71H Dunlop Qualifier K827Seat height31.2 in. (792mm)Ground Clearance5.6 inc. (142mm)Fuel Capacity5.3 gal. (20 L)Curb weightfull tank 751.5 lbs. (340.8 kg)Test weight911.5 lbs. (413.5 kg)Power sourceAC MagnetoCharger controlSolid-state voltage regulator/rectifierHeadlight beamshigh/low 65/60 wattsTail/stoplights8/27 watts (2)Battery12V 18AHInstruments Edited July 21, 2013 by Yammer Dan
dacheedah Posted July 21, 2013 #3 Posted July 21, 2013 probably those big parachutes on your highway pegs
Venturous Randy Posted July 22, 2013 #4 Posted July 22, 2013 driving range 226 miles????? I get about 140! On a real good day, I think I could go 250 miles, but I would be empty. RandyA
Black wing Posted July 22, 2013 #5 Posted July 22, 2013 i dont get how you guys are getting such high mileage, i get 23 mpg with my trailer and 31 mpg with out it
Snaggletooth Posted July 22, 2013 #6 Posted July 22, 2013 driving range 226 miles????? I get about 140! 140 is where my fuel warning light comes on. About 225 my nerves tingle. Topped off a couple times at 4.8 gallons. I don't know if I could have pushed it further. Didn't have my gas can with me. The trick is in the wrist. Don't bend it so much.
