Will the xvz1300 stator fit in the xvz1200? does it have the same plug connector? added some lights, and the 1300 usually has more lights than 1200. So,. is this an inexpensive fix or what?
probably want to go with a Ricks Electric Hot Shot. I would also recommend replacing the regulator/rectifier at the same time. my choice is a Shindigen, 3 phase.
:sign yeah that:
Have a look here.
I put a Rick's High Output stator and a Shindigen R/R in my 89 VR and what a big difference in the way the bike starts and the stator runs cooler because it is not running at 100% power output. So the stator will last longer. Bike starts better and runs at higher voltage than with the original setup. 13.0 volts vs. 14.1 volts now. Also run the red and black wires from the Shindigen R/R directly to the battery posts and eliminate the wiring harness on the bike. R/R will sense the voltage at the battery and you will get better & more consistent voltage for the bike.
Jim
