Guest tx2sturgis
Can you tell me what they are exactly...and how much?
I'm waiting on a set of RK pipes, and if your brackets will make the job faster, easier, or look better, then I'm in.
Thanks.
I know this has been beat to death but never paid much attention to that one. What does it take to put these things on a 1st Gen?
Dan,
I know there have been a few members that have installed the R/K pipes on a 1st gen. It's not a simple a swap as it is on a G2 the bracket mounting techniques are varied. I know that Dragonrider has a set on his '83 and Don B out of Ontario has a set too. Might want to PM one of those fellas and they can fill you in a bit more, or just type it in search above.
Thanks.
Brian,
The brackets do make it virtually painless, they are hidden so you dont see them as they are under the saddlebags. They bolt directly onto the H/D mufflers and are designed to bolt directly into the factory mounting spot where the stock mufflers hook up. Here's the post I have in the classifieds.
http://www.venturerider.org/classifieds/showproduct.php/product/288/cat/7/limit/recent/date/1157932426
I think Mother just finished installing a set on his 86 as well
Brad
