plumberman Posted July 13, 2013 Posted July 13, 2013 THANK YOU VERY MUCH FOR POINTING ME IN THE RIGHT DIRECTION ON THE NO STARTING 2008 . IT TURNS OUT TO BE AN OPEN WIRE FROM START SWITCH TO THE 12 PIN STARTING CIRCUIT CUT OFF RELAY . HAVEN'T HAD TIME TO TRACE IT YET , MITE HAVE TO RUN A NEW WIRE , JUST GLAD TO KNOW WHAT IT IS .WOULD HAVE BEEN LOST WITHOUT YOUR HELP TO KNOW WHERE TO START . THANK YOU ONCE AGAIN AND THE PEOPLE AT THIS SITE ARE GREAT !!!!!!! ( MIKE )
dingy Posted July 13, 2013 Posted July 13, 2013 THANK YOU VERY MUCH FOR POINTING ME IN THE RIGHT DIRECTION ON THE NO STARTING 2008 . IT TURNS OUT TO BE AN OPEN WIRE FROM START SWITCH TO THE 12 PIN STARTING CIRCUIT CUT OFF RELAY . HAVEN'T HAD TIME TO TRACE IT YET , MITE HAVE TO RUN A NEW WIRE , JUST GLAD TO KNOW WHAT IT IS .WOULD HAVE BEEN LOST WITHOUT YOUR HELP TO KNOW WHERE TO START . THANK YOU ONCE AGAIN AND THE PEOPLE AT THIS SITE ARE GREAT !!!!!!! ( MIKE ) Even better is not ever owning or really seeing deeply into a complete RSV. It's great to be a good guesser !!! Glad I could help. Gary
Rick Haywood Posted July 14, 2013 Posted July 14, 2013 THANK YOU VERY MUCH FOR POINTING ME IN THE RIGHT DIRECTION ON THE NO STARTING 2008 . IT TURNS OUT TO BE AN OPEN WIRE FROM START SWITCH TO THE 12 PIN STARTING CIRCUIT CUT OFF RELAY . HAVEN'T HAD TIME TO TRACE IT YET , MITE HAVE TO RUN A NEW WIRE , JUST GLAD TO KNOW WHAT IT IS .WOULD HAVE BEEN LOST WITHOUT YOUR HELP TO KNOW WHERE TO START . THANK YOU ONCE AGAIN AND THE PEOPLE AT THIS SITE ARE GREAT !!!!!!! ( MIKE ) If you end up needing new starter cutoff circuit relay don't order one. I have a brand new one still in the box Rick
