charlie h. Posted July 13, 2013 #1 Posted July 13, 2013 Hi Guys and gals! has anyone successfully added a steering damper to the 1st gen Venture? I have owned several, and it seems that would be a great upgrade for stability. I have Progressive springs, and new lower fork bushings and slider bushings, and will add a condor fork brace soon. I believe that a steering damper could be added with positive results also. Anyone ever do this??
Snaggletooth Posted July 13, 2013 #2 Posted July 13, 2013 Never gave it much thought as I'm pretty happy with the handling on my '84 with the Progressives and Condor Brace and I push the bike pretty hard sometimes. I'd have to say installing one might be a bit of a challenge with the fairing and cowling pieces around the neck and tree area without some serious changes. Be watching to see what you end up with.
Marcarl Posted July 13, 2013 #3 Posted July 13, 2013 If you tighten the bearings just right you don't need a damper, but it can be a bit tricky at times, in this case a little can go a long way.
