I bought a 99 venture a month ago, getting ready to change oil, whats everyone using as far as wt (10-40,20-40,20-50)??
I use 20/50 Castrol. Plain old car oil!! In my opinion anything else is a good way to throw money away!!!Use a good oil and change it as you should. OK back to the corner.....
That must be why 1st gens are faster :stickpoke:
Ok boys, and gals, pull up your rockin chairs.
I use the yamalube ( mostly because i'm still under warranty ) manual suggests 10w30 for cold weather, 20w50 for hot weather.
Most dino is ok as long as no friction modifiers
No matter what oil you choose replace the crush washer (214-11198-01-00) and torque to 31 ft lbs
Thanks guys. I always used 20-50 in my 83 venture and have been happy with that. The book on the 99 shows 10-30 or 20-40 but nobody has 20-40.
