Aimhigh Posted February 18, 2008 Posted February 18, 2008 is this the same as the Progressive pump you all talk about? http://www.mawonline.com/newsite/progressive_suspension-gauge_mounted_shock_absorber_pumps.htm
Joopster55 Posted February 18, 2008 Posted February 18, 2008 It looks like it. Low pressure. Got mine from Custom Cruising. Works very well. Careful when adding air to the front forks, only needs about 3psi.
hipshot Posted February 18, 2008 Posted February 18, 2008 mine came from yamaha! just push a button, and "wallah"!!! add air/ release air! and you guys thought you were trading UP????? lol just jt
RedRider Posted February 18, 2008 Posted February 18, 2008 That is the correct pump and a good price too. When I bought mine last year the best price was from the HD dealer - about $45. RR
Squidley Posted February 18, 2008 Posted February 18, 2008 Thats very similar to what I have been using, I would snag it
Bummer Posted February 18, 2008 Posted February 18, 2008 Get #27877 for the front. #27873 for the rear and tires. You can make do with the 27873 but it'll be a bit difficult to properly adjust the fronts. 27877 has a large syringe style body which, when combined with the low pressure gauge, makes it easy to match the low pressures in the front shocks.
