the right rear blinker isn't working...again...dang electrical gremlins. VR gremlin bell isn't working. maybe its under warranty...the bell, that is...anyhow...right blinker makes a clicking sound near front of fairing. probably one of the many unmarked relays....left rear blinker works fine. any help? thanks in advance. RDM. AND before someone says it...blinker fluid is full!
its the entire right side of bike.
Well, there are only two lights to flash on the "entire right side of bike".
So, it's NOT just the right rear. It's ALSO the right front not flashing.
When you put the Hazard flasher switch to ON, what lights flash?
can I replace it with a inexpensive 2 prong..i know I will lose self cancelling feature...right?
Yes. And yes.
Note: if you hook it up wrong you will blow a fuse. Have some spares?
