wkoepke Posted June 26, 2013 #1 Posted June 26, 2013 can someone PLEASE tell me what size jet goes in this block? have two that are .030 dia. and two that are .050 dia. also what size goes in second pic? thanks, bill
abusive throttle cranker Posted June 26, 2013 #2 Posted June 26, 2013 I had the same problem. Research THOROUGHLY! I found the answer- you will too. P.S. research HERE thoroughly.
dingy Posted June 26, 2013 #3 Posted June 26, 2013 can someone PLEASE tell me what size jet goes in this block? have two that are .030 dia. and two that are .050 dia. also what size goes in second pic? thanks, bill The lower opening on the first picture is the main jet. #125 for the 86. Also, in the 1st picture, left port on bottom is the idle jet, #37.5. Make sure this on is shiny clean !! The one on the top of the 2nd picture is a #80 air jet. Sizes are imprinted on top surface of jet. Gary
Scudrunner Posted June 29, 2013 #4 Posted June 29, 2013 Abusive Throttle Cranker's "HERE" is not a link. I found the page in the manual that details the jets and their location but the numbers don't give their actual sizes. Some of the jets I have are not stamped clearly so I too would like to know the actual diameters of the jets and their proper locations in the entire carb.
dingy Posted June 29, 2013 #5 Posted June 29, 2013 (edited) Abusive Throttle Cranker's "HERE" is not a link. I found the page in the manual that details the jets and their location but the numbers don't give their actual sizes. Some of the jets I have are not stamped clearly so I too would like to know the actual diameters of the jets and their proper locations in the entire carb. Attached are some charts and a somewhat lengthy, but basic overview of carb principles. Gary Edited June 29, 2013 by dingy
wkoepke Posted June 29, 2013 Author #6 Posted June 29, 2013 Gary, thanks for the help, bike runs great when the jets are right! scudrunner, #80 jet is .031 dia. and the main jet is #125 .050 dia. I checked them with my gage pins that are minus .0002. hope this helps, bill
Scudrunner Posted June 29, 2013 #7 Posted June 29, 2013 Dingy, I didn't see anything for your last posting re: carb info.
dingy Posted June 29, 2013 #8 Posted June 29, 2013 Dingy, I didn't see anything for your last posting re: carb info. Fixed attachments. Gary
Scudrunner Posted June 30, 2013 #9 Posted June 30, 2013 Thanks Gary and Bill. I have an 84 so I know the one jet is a different size which I have found. I pulled all my jets after I looked at one a saw 117 on it and stripped the others down. Come to find out the PO had the carbs worked on and some of the jets have a different marking or none at all. Will probably order some new sets to be sure they are all the same. Did notice in some of my reading that sometimes the jets in the rear cyls. might have a slightly different jet than the front cyls. Anyone do this to their bike?
Scudrunner Posted July 16, 2013 #10 Posted July 16, 2013 Got everything together and engine runs pretty good now but still needs some fine tuning. Couldn't have done it without the help from the group here. Looking forwards to a North FL meet and eat sometime. Thanks to all.
