I learned the 9 dollar compressor from HF will not pump up a flat motorcycle tire, I will either get the co2 cartridges or a better pump. The way the piece of metal went in the tire the plug did not seal it very well I think it tore the inside of the tire.
Got cheap tire inflator with light at Wallmart, which I attach to our battery tender harness. Use it often to top off our trike tires, not just for emergencies. It also works fine on Jeannette's car. Also carry tire plugs and Slime. That is a nasty piece of metal!
Joe, if you still want Harbor Freight they have a good air pump (item no. 69284) on sale for $26.00. all metal compressor high volume low pressure. That $10 one is a toy. Good Luck.
Hope things worked out Joe. 1st time on line since I got home Sun. I live in Louisville, so, the next time you're going to be near, gimmie' a shout out and we'll get together for a talk and a bite to eat.................luck! bill4you502
