I bought all the stuff for the carb synch,
i have 32 inches above the fluid line.. for clear tubing , without the motor running.. actually each tube is 20feet long total
so i start it up and 3 and 4 suck the tranny fluid up 32 inches before i can cut it off,,THAT FAST...YES,, ALMOST TO MOTOR BEFORE I SHUT IT OFF
1 AND 2 ARE SLOWER,, RUN TRANNY FLUID DOWN THE TUBE three times ,, finally unhooked 3 an 4 so i could atleast do 1 an 2 ,,,
little slower yet still sucked it all the way to the top
as of right now i have tubeing hanging off the gutter of the house an i cant start the bike long enough to turn any screws bofore it sucks it down
please tell me what i can do ??????
sure looks like i fixed vacuum leaks REAL GOOD,,,,,,,, IT IS AN 89 1300
Edited by Big Lou
Attached is one I made several years ago. All 4 tubes are tied across bottom manifold.
You want vacuum tubes on top, to try & lift the column of fluid. And if one starts pulling real hard, then adjust the corresponding sync screw. Idle setting is # 2 carb, sync others using #2 as reference.
Procedure is in service manual.
I attached a PDF of a few pages from 86-93 service manual. 83-85 is same.
Gary
Edited by dingy
Problem with your setup is you need a restriction in the line. Not really sure of exactly what hardware you need to do that, but someone else will jump in here.
I purchased rather than made my manometer.
TIED END OF LINE ,
THAT IS IT
NO MORE SPITTING SPUTTERING ,
CRANK THE THROTTLE AN NO HESITATION AT ALL
IOU;;;;; WHEN YOU WANNA RIDE TALLADEGA NAT. FORREST
IOU YOU BOTH A STEAK...I LIVE ON THE HIGHEST POINT IN 10 MILES I CAN SEE THE CURVE OF THE EARTH OVER FORREST, NO HOUSES ,, GOT TWO BUILT IN BBQ GRILLS
AND PANAMA CITY IS 3 HOURS AWAY
IOU IOU IOU:cool10::cool10::cool10::cool10::cool10::cool10::cool10::cool10::cool10:
CARB SYNCH IS AS CLOSE TO PERFECT AS I CAN GET, ONLY CAUSE THE army TAUGHT ME NOTHING IS PERFECT
as i finished synch, the tubing on number one ,, melted and in the line is dark color then turns to a light yellow up the line ,,?????????????????????????????????????????????????????
dont know why
as of right now it aint spitting ,or , anything , cant ride it till later tomorrow
dog died .. darn,,
i took off starter to fix dragging .. the plastic ring is melted ,, brushes are fine ,, i will fix it before everybody gets up in the morning,,, will post pics as soon as i figure out how , without getting a headache
got to tend to dog
