Gets right to the point !
Let me say - steering head - tighten
Now who is being a tough crowd :stickpoke: At least he came back and edited his original post. :stirthepot:
I would second the steering head bearings if you had them re-packed at 16,000 miles try the cheat method for tightening.
That was funny ! I see I'm not the only one that reads most of the posts.
OH CRAP you mean I got to take all that junk apart and pack them things. Man that will take all winter. Mostly because I'll have to work up the gumshion to do that kind of a job.
Where you live I would bring it in the house and work on it during the summer in the AC and ride all winter.
front end wobble.high and low speed.2007 venture,35000mi.
John, check your neck bearings. It probably need adjustment. I would try the short cut method first. Tire pressure may also be too low. Try running with 42-44 up front. Miles on tire? May be worn and scalloped.
