REDRIDER52 Posted June 3, 2013 #1 Posted June 3, 2013 I was under trike greasing cv joint and saw 2 zerk fittings on swing arm BUT I could not get grease gun hose on it its turned towards the front of the fender any ideas on howto get on it to grease the swing arm. will try to post picture taken with cell phone
CaptainJoe Posted June 3, 2013 #2 Posted June 3, 2013 just put a open end wrench and move the grease zerk... sorry i see now its a straight one...oooops! buy an angled grease zerk. The come in different angles including 90 and 45 deg..
Carbon_One Posted June 3, 2013 #3 Posted June 3, 2013 I took off the straight zerk fitting and replaced them with a 90* one. Turned them so they pointed down and now can grease them easily. Larry
REDRIDER52 Posted June 3, 2013 Author #4 Posted June 3, 2013 do you know what size they were standard or metric
ragtop69gs Posted June 3, 2013 #5 Posted June 3, 2013 I took off the straight zerk fitting and replaced them with a 90* one. Turned them so they pointed down and now can grease them easily. Larry
bongobobny Posted June 3, 2013 #6 Posted June 3, 2013 The ones on the swing arm should be the stock metric...
ragtop69gs Posted June 4, 2013 #7 Posted June 4, 2013 The ones on the swing arm should be the stock metric... They make metric Zerk fittings ?
Trader Posted June 4, 2013 #9 Posted June 4, 2013 Contrary to popular opinion...there is more to the world than the USA ..... and MOST of the world uses metric!!!!!! (get the popcorn ready!)
Big Lou Posted June 5, 2013 #10 Posted June 5, 2013 I heard a song once ,"",we are the world"" be all you can be
dacheedah Posted June 5, 2013 #11 Posted June 5, 2013 Contrary to popular opinion...there is more to the world than the USA ..... and MOST of the world uses metric!!!!!! (get the popcorn ready!) Apparently most of the rest of the world makes the stuff I use, most seems metric to me
ragtop69gs Posted June 5, 2013 #12 Posted June 5, 2013 Apparently most of the rest of the world makes the stuff I use, most seems metric to me A backwards bunch they are
