msshearin Posted June 2, 2013 #1 Posted June 2, 2013 http://www.foxnews.com/leisure/2013/05/29/unique-motorcycle-safety-device-aims-to-reduce-rear-end-collisions/?intcmp=features
Freebird Posted June 2, 2013 #2 Posted June 2, 2013 I was posting about it the same time that you did. I deleted mine. I actually don't think it's a bad idea.
brd7666 Posted June 2, 2013 #3 Posted June 2, 2013 I like it, hopefully they will raise enough money for it to go in to production.
msshearin Posted June 2, 2013 Author #4 Posted June 2, 2013 yeah it sounds like a really good idea to me too
mbrood Posted June 2, 2013 #6 Posted June 2, 2013 Not too hard to cludge up with a slightly tilted Mercury switch. The previous owner of my xs750 tossed something like that together with two tilted left and right and wired into the ignition as a tip over engine kill... except if you went real slow around a very tight turn, it would temporarily kill the ignition... and I found this not condusive to safe driving, darned scary, so it got the ole heave ho to the garage parts bins. I'm sure exhaustive adjustment would have found a happy setting but I wasn't about to pick it up a few more times in an intersection.
dacheedah Posted June 2, 2013 #7 Posted June 2, 2013 not a bad idea, when planned i downshift before breaking
etcswjoe Posted June 2, 2013 #8 Posted June 2, 2013 I talked to someone a year or two ago that had a similar idea but never did hear how it worked out.
Guest divey Posted June 2, 2013 #9 Posted June 2, 2013 I was following alongside an HD a few weeks ago in stop and go traffic. He had an array of lights on the back and every time he applied his brakes, all the lights would flash maybe three or four times and then eventually stay on bright until he released the brake. I noticed he had it rigged up to work with both the front and rear brake. Didn't matter which one he was using to stop with. The flashing sequence was the same each time. Never seen it before but it was very effective in getting your attention whenever he was starting to brake. Would be a real good setup to have. Doug
Marcarl Posted June 2, 2013 #10 Posted June 2, 2013 I was following alongside an HD a few weeks ago in stop and go traffic. He had an array of lights on the back and every time he applied his brakes, all the lights would flash maybe three or four times and then eventually stay on bright until he released the brake. I noticed he had it rigged up to work with both the front and rear brake. Didn't matter which one he was using to stop with. The flashing sequence was the same each time. Never seen it before but it was very effective in getting your attention whenever he was starting to brake. Would be a real good setup to have. Doug I don't mind this idea, but the idea of my brakes lights coming on everytime I slow down a bit, would drive the driver behind me nuts and soon he/she would not pay much attention to my brake lights coming on.
Brake Pad Posted June 2, 2013 #11 Posted June 2, 2013 this system is used on Coach buses, when going down hill, take your foot off the brake, and downshift, the big light strip goes on as you roll down an incline
