Does anyone know if there is a fuse that goes to the cms, mine is a 1988 royal
My warning light fuel gauge and clock are all out.
Thanks allen
Thanks allen
Signal fuse, only 20 amp one on the 86-93's
Horns, tach, volt thermo, CMU all run on this fuse.
Gary
put in a test ground, spike the wire at each connector, if it works at the device move back until it doesn't and you have isolated that. I would check fuse and the serviceability of the fuse holder first.
used a test light and found there is ground in the large plug on the back of the cms
Edited by wecruz
Try unplugging the wire harness from the back of the dash and look at the connectors. Look for obvious corrosion and broken wires/spades. Let us know how it looks, electrical gremlins suck!
plugs and terminals all looked like brand new as well as the boards....
Check for cracks on the solder joints, on the backside of the CMS plug terminal. These were known for cold solder joints, just like the CLASS Controller, in the right fairing. Check the tech library, for instructions, to fix these issues.
