After searching forum I found most tire info to be from 2011 and back, with alot from 08 09. thought it mite be time to get new perspective. I need tires, and thinking radials. your thoughts. bike has a 130 junkmaster on back now. sizes you are running? I,m thinking stock on front with 150 in back. thanks sandy
Got a 89 Venture, calls for 140/90. ;; Took off a mu90B16::: dunlop E3, tread wore flat, ,hard edge, ,,
I put on a 150/80-16. I found on a wrecked harley,,,,it is a dunlop 401;
I think it is a way softer tire,,i dont slip or slide an it makes chirping sounds when i down shift,,
it was a wiggling issue to get it on, otherwise, it handles great like it takes curves by itself
Greetings brother Big Lou; You mite want to check load rating on that. mite be little lite for venture. think maybe a 71@ about 670lbs max
