Trader Posted May 30, 2013 #1 Posted May 30, 2013 (edited) Please look at Post #5....that's where I'm at now. Edited May 31, 2013 by Trader
Trader Posted May 31, 2013 Author #3 Posted May 31, 2013 You know.....I just disconnected the ground....seems OK so far. So now I need to find a hot wire when the key is on. I don't want the driving lights HOT...even thru a switch . IT would give me more peace of mind to run thru a keyed power line. I read about hooking into the headlight wire...but wouldn't the driving lights put too much extra drain on that circuit? Same thing if I hook into the 10a. "ACC" circuit I already have a rear end full of running lights on that circuit. SO....can anybody tell me a keyed hot wire that the driving lights won't over amp?
dacheedah Posted May 31, 2013 #4 Posted May 31, 2013 I would suggest running through a switch and then a relay to the lights.
Trader Posted May 31, 2013 Author #5 Posted May 31, 2013 While I've been trying to sort things out I searched the site and found this diagram. Seems simple enough. So....could someone please tell me if I'm right here....... in the diagram attached....the key switched power goes to terminal #86 and the fused power comes from the battery to the #30 terminal Then run a ground thru the operating switch to terminal #85 Does that mean the passing lights will only operate if the key is on?
MikeWa Posted May 31, 2013 #7 Posted May 31, 2013 The diagram you have is fine. The lights will only work when the key is on. The only suggestion I would make is you move your auxiliary light switch to terminal 86 and connect 85 directly to ground. I just prefer that when I turn a switch off it interrupts power to the circuit. Mike
Trader Posted May 31, 2013 Author #8 Posted May 31, 2013 Thanks a bunch...that's what I needed to know.
paysaw Posted May 31, 2013 #9 Posted May 31, 2013 Yes Steve that will work fine.I used the same kind of Idea on my 84 lighting mod.
