pmelah Posted May 25, 2013 #1 Posted May 25, 2013 ok here is what i got or get and i dont know if im doing this right i check my leads from the plu to the tci to # 1 2 3 4 coil red lead to power # 1 pin and black lead to pin 2 and get a reading of 22.4 ohms on 200k setting black lead on pin 3 reads 24.2 pin 6 29.6 pin 7 22.7 i get the same readings with red lead on pin 1 and black lead to each plug boot cap can some one tell me what im doing and if it wrong because i cant get any of my coils to read 2.7 ohs on any setting
dingy Posted May 25, 2013 #2 Posted May 25, 2013 Attached is a page from manual showing procedure. Lower two pictures. Readings are shown above meter. This is 86-93 manual, RSV will be similar. Gary
bongobobny Posted May 25, 2013 #3 Posted May 25, 2013 Are you disconnecting the coils from the wiring harness? Is the battery in your meter fresh? I seem to remember something about the test procedure using an old analog meter movement as opposed to a digital movement. Try a different meter as well...
pmelah Posted May 25, 2013 Author #4 Posted May 25, 2013 digital is all i have and probably needs fresh new batteries since i havent changed them sice i got it brand new 4 yrs. ago
pmelah Posted May 25, 2013 Author #5 Posted May 25, 2013 Attached is a page from manual showing procedure. Lower two pictures. Readings are shown above meter. This is 86-93 manual, RSV will be similar. Gary thanks Gary this one i did not have saved to my laptop but it is now
mbrood Posted May 25, 2013 #6 Posted May 25, 2013 Pulling the large white connector off the TCI and read resistance between the ignition fuse and the connector's pins 2, 3, 6 & 7 for your primary coil resistance. http://www.bergall.org/temp/venture/tci/tciplugs.jpg
