easternrider Posted May 24, 2013 Posted May 24, 2013 (edited) For the 84's, can someone tell me if the parts are interchangeable. I have the V Std, and may buy a Royale for the parts. I specifically need the forks (if they are good), then could use some other things, and spares. Thanks Edited June 1, 2013 by easternrider
Wizard765 Posted May 24, 2013 Posted May 24, 2013 If you are talking about both being 84 then the only real difference is the electronics. The VR has CLASS. AM/FM, Cassette, Cruise Control and Intercom. Body panels and mechanical parts like the forks are totally interchangeable.. The only body parts not interchangeable would be the upper fairings that hold the electronics.. If the VR that you get has working electronics then you might want to turn your standard into a Royale. I like having music and an intercom as well as cruise.
easternrider Posted May 24, 2013 Author Posted May 24, 2013 Thanks. Thats what I was thinking, most would interchange, but could not find any reference to it. I was told the only thing that did not work was the leveling module for the air ride, and a couple of parts missing (almost complete).
