Boe Posted February 12, 2008 Posted February 12, 2008 Lowering 3" and forward 3" for tall passenger. I cut off the hinge of the yamaha mount and welded 1/4" plate horizontally to add length to clear side pipes. then welded plate at 90deg vertically to drop 3" down and forward. I took the passenger floorboard mount from a HD and cut and welded the floorboard hinge point to the bottom of the vertical plate. I used to HD mount so I can use what ever after market floorboard I choose. I am going to use Kuryakyn. After a dry fit for clearance I will finish the welds and remove the excess mass of the plate by cutting to a more attractive profile. Final step will be to have the piece chromed and mounted. Will add pics after next step.
Eck Posted February 12, 2008 Posted February 12, 2008 Looks like a very neat idea you have there. A little dressup sanding, add a little paint and it will look almost like OME. A very cool idea !!!!!!!
