So finally the snow is gone and I put on a couple hundred miles on Sunday. Monday, went out to jump on and heard a rattle. At first I thought it was an engine knock, but after some investigation, it is the exhaust collector. Some pieces broke of on the inside and are rattling around. So after a while and some swearing, I have the exhaust pulled. The broken pieces are too big to pull out of a hole.
Now what?
Should I just start looking for another collector?
Or, could I cut a bigger hole in the bottom, pull out the pieces and weld it back together?
Any input would be greatly appreciated.
Thanks.
Aaron
MN
Thanks a lot. That second one is sort of what I had pictured in my head. I played with it for a while, and found it was two broken pieces. One was smaller and I was able to twist and bend it enough with a long needle nose to get it out. The other is bigger, I tried the same thing but pretty much bent it into a big ball that's bigger than the holes, so it won't come out. I guess I'll be performing surgery soon.
I had pretty much the same problem last Summer.
I ended up replacing the collector with one I got from Dingy.
I cut the old one apart, and found the problem was actually that the divider had broken loose from the base. (spot welds)
I welded it all back together, and as far as I can tell, it should be fine.
If you can't get yours to work, lemme know and we can work out a deal on the one I repaired.
Hell,....you can have it if you want,.....just pay for shipping.
If you click on my profile and search "links started by uncledj", there's a thread titled "Exhaust collector repair" There's pics of the collector cut apart then welded back together.
Lemme know :080402gudl_prv:
Thanks, I'll let you know how mine goes. I'm looking forward to a welding project.
  • 4 weeks later...
Got it all back together and finally the rain let up so I can ride. I had my brother in law weld it for me, he's a welder so I figured he could do a better job. The bike runs great still and doesn't sound like its going to blow up.
Thanks for the help.
Aaron
