Ozlander Posted May 14, 2013 #1 Posted May 14, 2013 I want to reprogram my TCI. Can't get the laptop to talk to the TCI. I'm using the usb to serial adapter that I use on the sewing machine. Using com 4 which is what the laptop says it's using. Any tips.
dingy Posted May 14, 2013 #2 Posted May 14, 2013 I want to reprogram my TCI. Can't get the laptop to talk to the TCI. I'm using the usb to serial adapter that I use on the sewing machine. Using com 4 which is what the laptop says it's using. Any tips. Upper left corner of software screen, click on COM, in this menu click on com auto, bottom choice. That will let software scan to find a port it is happy with. Key must be in run position, without motor running. Gary
Ozlander Posted May 15, 2013 Author #3 Posted May 15, 2013 Tried the com auto thing for 5-10 minutes, both engine dead and running. All it did was to cycle thru all the com ports.
dingy Posted May 15, 2013 #4 Posted May 15, 2013 Tried the com auto thing for 5-10 minutes, both engine dead and running. All it did was to cycle thru all the com ports. What operating system are you using? Windows XP, 7, other? Call me tomorrow night, I will work through it with you. Gary
Ozlander Posted May 15, 2013 Author #6 Posted May 15, 2013 It started working, screwed around with it for a while, moving wires and stuff. Reprogramed it using the last program you sent me, that went good. But, I'm not getting any readings from the map sensor. Going to check the wring. Merlyn
