Big Lou Posted May 11, 2013 #1 Posted May 11, 2013 FIRST thanx for any help. i bought the blue beast in the dark, it has lots of previous owner fixes looks like in the dark/ got a good deal rode 4 hours home on it .due before is light for a big bike .scratched good...him too.left red light in a hurry after riding off a cliff .yea i didnt scratch it any more than it was allready scratched , thing is tough , now have a misturous knock heavy knock/ hold your hand over output shaft on transmission an feel it . needed tire anyway. so got new tire on a while its off doing best on knock, due at one shop heard it took it to him on center stand he siad DONT RIDE IT , so its my only way of going. no chips or pieces in rearend pulled swing arm greased bearings, no visible wear , i am an experienced mech on big trucks an cars so i can do this, now after all inspections ujoint is good, pulled motor split cases ,truly a million pieces, ok ,.got tranny in hand cant see nothing broke. took all pieces including rearend tranny lock stock an barrel to schooled dealer , he didnt find nothing either . bearings are fine casing halves are fine , knock only in gear not idle or hard throttle on stand , it is loud casing has no scoring from gears ,only thing i found is where dude before me left out 3 of the ???locks or shims that go in the case for the bearings on tranny 2 peice split ring ,knock is scary dont want to get hurt. younguns at shop said he dont know .he went to school. 4 people looked at it at dealership????????
Peder_y2k Posted May 11, 2013 #2 Posted May 11, 2013 Missing tranny locks/shims, or whatever they are, can account for excess end/side play (clearances) that create the loud sounds. The side play can cause the gears/parts to bang loudly together with each power pulse from the engine. -Pete, in Tacoma WA USA '83,88
Big Lou Posted May 11, 2013 Author #3 Posted May 11, 2013 i am hoping so tuesday they come in , 10.00 for them.cogs look good going to put new ujoint in anyway cleaned everything only suspect is where middle shaft last two gears are when pushed together and turned with force they click right next to spring dont see no cracks or out of ordinary wear .for real .i think with out retainers an with all glue till i really torqued on it it was all in line , my real question is the book says SMOOTH operation cant i take a really small amount of metal off where clicking noise is ??? dude at shop said no parts after ten years. i really aint scared of it now i seen it . could it actually shift that much with blocks at each end of shaft from cases?????cases have no wear in dead spots where shaft ends ,,thank you for your opinion i have been doing cars an big trucks for 35 years , 63d in army . nevr seen knock didnt have something broke or wore it was the worse i have ever seen an still run on anything,litterally feel it on engine block, tire jumped , all that
muffinman Posted May 11, 2013 #4 Posted May 11, 2013 Look at the drive shaft and cup in the final.drive it sounds to me like the drive shaft might be skipping in the cup had that problem on a few I worked on and it sounded like the problem was in the middle gear. What year is the bike? Jeff
Big Lou Posted May 11, 2013 Author #5 Posted May 11, 2013 Ok I pushed shaft into housing for driveshaft where spring is with it on the bike an tire mounted, and on the table by it self, see no or feel no grinning or slippage in driveshaft, its an 1989 1300; Venture royals, don't know if just saying venture is different, truly a massive, comfortable beautiful beast, an my only way of going, so if I put it all back together, I will break it down a second time, , I live in the woods an my driveway is almost a mile long around the an up a rocky road, ,I tell everybody if I make it to the pavedroad I am fine,,takes 2a people to pick it up
Big Lou Posted May 11, 2013 Author #6 Posted May 11, 2013 I am going to change joint anyway, doesn't look bad, no grease fitting an I can get a joint for a pto shaft that has a hidden or flat, depending on your terms,grease fittingfitting in the end of a cap, I don't like having peices with grease I can't grease , learned hard way on dirt road,,,
