Wendell Posted May 9, 2013 #1 Posted May 9, 2013 Does anyone have any problems cornering with the Baron 4-2-4 slip-Ons?
2WHEELSFORME Posted May 9, 2013 #2 Posted May 9, 2013 No problems but I have installed the leveling links so it sits a bit higher. I also put some extensions on the pipes and the set bolt that holds them on will touch a little but it's not a problem. Except for flatting out the screw head so you need channel locks to remove.
