friesman Posted May 8, 2013 Share #1 Posted May 8, 2013 I went out to my new to me 2003 RSV today and noticed the CB antenna was missing above the lower ballast collar. I don't know what happened to it, but I am looking for a replacement and it doesn't have to be OEM style. I don't know anything about electronics so I would like it to be a screw on replacement if possible. The local dealer just informed me that he is asking 246 for the cb mast, and partshark is 154 and boats.net is 176. I was thinking for that kind of price I may be able to get a newer style solution. Thanks in advance for you ideas, Brian Link to comment Share on other sites More sharing options...
painterman67 Posted May 8, 2013 Share #2 Posted May 8, 2013 this is what I did. Its on a 91 but it works great. I guess you could do it twice so the radio antenna matches http://www.venturerider.org/forum/showthread.php?t=57269 Link to comment Share on other sites More sharing options...
XV1100SE Posted May 8, 2013 Share #3 Posted May 8, 2013 Not sure if a place that sells cb's would be able to suggest something. Issue might be the mount. Link to comment Share on other sites More sharing options...
etcswjoe Posted May 8, 2013 Share #4 Posted May 8, 2013 Here is the link to Marshall mod, you can do just the CB and it will not run you that much. http://bludolphintravel.com/gmg/marshallmod.htm Link to comment Share on other sites More sharing options...
XV1100SE Posted May 9, 2013 Share #5 Posted May 9, 2013 Here is the link to Marshall mod, you can do just the CB and it will not run you that much. http://bludolphintravel.com/gmg/marshallmod.htm Wish he'd change the back ground and text - find it difficult to read. Especially the white on white ! Link to comment Share on other sites More sharing options...
friesman Posted May 9, 2013 Author Share #6 Posted May 9, 2013 Wish he'd change the back ground and text - find it difficult to read. Especially the white on white ! I agree, but if you hold your mouse button down and drag across the page it changes the volour enough to read it. Brian Link to comment Share on other sites More sharing options...
