At one time I saw some pictures where someone had relocated the battery to where the coils and TCI normally reside. I can not find them, if anyone knows where they were or if you are the one who did the relocation I would like some pics. I'm looking to move my battery to that location.
Thanks
Thanks
That would have been me.
I will try to post something tonight.
Somewhere I have pictures on site already. Was putting in a VMax airbox.
Gary
Pictures attached
1st thing was I went to Coil Over Plugs to eliminate the standard coils & plug wires. Do not do this with a stock TCI, without adding resistors in coil power circuit. COP's are lower ohms and will kill a standard TCI. PM me if you want more info on COP's. You are getting an Ignitech unit, which has a setting in it to handle COP's without added resistors.
Fabricated a box from 1/8" aluminum that bolted where the coil rack was attached at. The gizmo mounted under box in a couple of pictures is the motor that controls the VBoost butterflies.
Battery is a Deka AGM, this can not be done with a standard lead acid wet cell.
Overall, driving force behind this was to get better VMax air box on bike.
Gary
  • 2 weeks later...
Dingy
Do you have plans or dimensions for the battery box you made.
Or better yet, would it be possible for you to make another. I'd gladly pay. I'm a good mechanic but not much of a fabricator
Sent from my HTCEVOV4G using Tapatalk 2
