I am wanting to be more hands on with my bike. I was told that changing the oil and oil filter is pretty easy. Does anyone have a step by step guide on how to change the oil? I have a 2007 RSV.
Pictures would be the best.
Chris,
This is really the easiest bike or car I have ever changed oil on.
One bolt, 17mm, already in perfect drain position. And easy to get to oil filter.
Might use a big channel locks to loosen it.
Remember to put a drain pan under it,,,lol.
That is really about it. 15-20 minutes without beer.
Mike G
Just don't over fill it I think manual states 3.5 qts w/filter I would add 3qts fire it up and run for a bit and check it. To much and it comes out the little rubber hose hanging by the swingarm. You don't want anyone thinking it's a HD.
Manual calls for 3.9 qts. 3.5 is perfect as it puts the oil at the 1/2 way mark on the window. Since your not familiar with oil changes just make sure you use a motorcycle specific oil and not one with friction modifiers added such as regular automobile oils.
