Question: on 08 RSTD,
Can you just use a Barnett Pressure Plate unit, and leave the original OEM Clutch plates in place.
OR: Do you have to also use the Barnett set of new clutch plates ???
As I recall, on a 1st Gen you could just replace the pressure plate with the new Barnett unit. Not sure on 2nd gens ??
I ride Solo, no trailer, etc etc, :confused24::confused24::confused24:
I changed the organic plates in mine as "might as well while I'm in there" thing... They were cheap enough and I got 80K on my Barnett Clutch setup and still works great...
