Yooper got a problem with 1993, last fall had leak at the chamber cover so replaced the two gaskets now been working on new girl to get her ready to ride , started her today got her up to temp dropped the oil & filter went back in the garage later and the over flow was down and the oil sight glass was up almost to the top and i left it in the middle. So what do you guys think Thanks Yoop
Although the "twinkie" has been known as a major contributor of oil/coolant mix, if you are confident the seals were placed right and tight, I would pull the plugs and see if one is fouled (keeping fingers crossed for all equally lightly sooty). Have you checked the radiator for a gray scum on the top?
OK Coolant level will be different for hot and cold, cold being lower. As for the oil level, when was it halfway, just after pouring the new oil in? If so, oil was trapped in the upper areas and has drained down. Also when you first put in the new oil it does not immediately make it to the oil pan, it takes a while to get completely there...
From your description, there's coolant in the oil sump, and that's NOT good. Remove the oil drain plug and see what drains out, should be just oil, or what's left of it after the first draining.
If coolant in oil sump, then there's a head gasket failure. It is NOT LIKELY, but a coolant hose could have been connected to a crankcase breather fitting.
-Pete, in Tacoma WA USA
'83,88
The oil level was haft way an hour after putting in new oil also the over flow bottle was fill to the line and now its down about a inch,and sight glass is almost to the top all liquids were new.Wonder if that pipe in pinky was not right, no leaks there by there i mean on top of engine where rad hose goes to pinky. hope i made that clear enough. Yoop
"Pete, could you explain what you meant by coalent hose conected to crankcase beather
fitting. Yoop"
What I meant is that on rare occaisions, the hose fitting indicated by the red arrow is confused as a water/coolant line, when in fact it is a crankcase vent line leading right down into the oil sump. It has happened, not to me, but just sayin'......
I think bongobobny's response is the most likely scenario.
'83,88
If it was me I would drain the oil, if you have coolant in the oil it wont take long to trash the bearings. When you drain the oil and it if its bubly or frothy looking you are getting coolant in the oil.
You could also do a pressure check on the cooling system and that will tell you for sure.
Orlin
Got the twinky out all ready for the new rubber seals tomorrow morning sure hope that was the problem, oil is out prestone is out tomorrow maybe get a ride, be first for the season 60 last two days up here in the snow country. Yoop
So was there cross contamination evident when you drained the oil?? Inquiring minds want to know! If so make sure you flush out any residual, especially in the oil...
Ship for weather up here going to get back working on the bike tomorrow have to put the twinky oil lines in then fill and check again. Been ice fishing the last two days even out on the ice with sled , got 142 perch the last two days, fun fun fun. bergland up here got 11 inches of snow in the last 24 hours. Yoop
Well guys Thanks for all the help looks like bike is good to go been a nitemare but solved, put new rubbers in that oil small line in the twinky when i was in there and also put a little K seal in the prestone in case there was leak in head gasket, but all is ok now we need weather to ride. 73 Yooper
