hoggman73 Posted April 23, 2013 Posted April 23, 2013 Im looking foe a set of handle bar clamps for my 2005 RSTD. I nedd the individual clamps. I have the solid one piece clamp and changing the risers out and my one piece will not work. If you have a set send me a message. I just need the top clamps not riser and all. Thanks
djh3 Posted April 23, 2013 Posted April 23, 2013 If the upper piece of the OEM clamp will not work with your new riserer I would have to suggest that they are incorrect in size. If they are not correct they will not clamp the bars down and then you have safety issues. I know mine were what you might call a tighter fit with the tall riserers. I guess the machineing was a tick off. If you havent already put the forward (top) bolt in a couple of threads, then work on the bottom one getting started. How much do you think it is off? Are the dots on the upper clamps on the top (forward) position?
