tdcisme Posted April 19, 2013 Posted April 19, 2013 I just bought an 07 venture, I am absolutely in love with it. However, I cant find either of the 12 volt plugs. According to the manual, I should have two. I feel kinda stupid, but i cant find either, please help!
playboy Posted April 19, 2013 Posted April 19, 2013 The other one is under the seat not very useable because of the type of plug. Should be on the left side beside battery small white two prong plug.
MikeWa Posted April 19, 2013 Posted April 19, 2013 The front one is low on the fairing on the left side. Get off the bike and squat down to find it the first time. The rear is under the seat near the left side. But it is not a cigar lighter type plug. It is a white two wire connector that does not have the pins in it. Mike Note: You can order pins and plugs from Eager Beaver but they come in bulk. Might be an idea for a group purchase.
VentureFar Posted April 19, 2013 Posted April 19, 2013 I also have an 07 RSV and even with guidance I had a hard time finding the rear connector. Mine is factory zip tied to the frame on the kickstand side of the battery box in the back corner ( would that be driver's left ? or the right side of the bike when facing it or simply put directly under my left butt cheek. It looks like two narrow white cigarettes glued together. - not a regular cigarette lighter adapter. It is switched. That is where I got the switched power for my "passing lamps" AKA 650 foot flame throwers from visionxwholesale.com VentureFar...
bmxndad Posted April 19, 2013 Posted April 19, 2013 I only had my bike for 4 years before I figured out there was a plug in on the fairing. Use it all the time now that I know its there.
tdcisme Posted April 20, 2013 Author Posted April 20, 2013 thanks for the help everybody!! Now that I've found the one on the fairing, I dont see how I missed it.
VentureFar Posted April 20, 2013 Posted April 20, 2013 Ha, it was two weeks before I noticed the pull to talk switch.
IronMike Posted July 18, 2013 Posted July 18, 2013 I feel pretty good I found everything in two days, Freebird helped me so I guess I cheated. The plug under the seat, I think I might hook a relay to it and use it as a trip for some real power for something, Maybe a Blender so I can mix drinks while I listen to old cassettes.
spear Posted July 18, 2013 Posted July 18, 2013 When I bought my 2004 RSV in 2007, it came with ALL the original bits and pieces including the owners' manual. Funny thing that. Like most stuff I buy, even if I think I'm even half familiar with it, I sit and read the manual. That's why they provide the bl00dy things so you can become familiar with the product. Sheesh. Imagine the nightmare I had when I bought my VW Tiguan. The manual with that is like something for the space shuttle - but I read it - and cannot believe some of the technology they crammed into that vehicle. I love it.
Bubber Posted July 18, 2013 Posted July 18, 2013 When I bought my 2004 RSV in 2007, it came with ALL the original bits and pieces including the owners' manual. Funny thing that. Like most stuff I buy, even if I think I'm even half familiar with it, I sit and read the manual. That's why they provide the bl00dy things so you can become familiar with the product. Sheesh. Imagine the nightmare I had when I bought my VW Tiguan. The manual with that is like something for the space shuttle - but I read it - and cannot believe some of the technology they crammed into that vehicle. I love it. Isn't that cheating? Reading the Manual that is.
etcswjoe Posted July 18, 2013 Posted July 18, 2013 I went to cycle gear and bought a 12 volt outlet for $10 and with just a little enlargment it fit in the hole in the plastic cover on the left side cut the little white connector off and used it to power a relay so I could use the plug for a compressor.
dacheedah Posted July 18, 2013 Posted July 18, 2013 http://www.starmotorcycles.com/assets/service/manuals/2007/LIT-11626-20-24_venture_1307.pdf
VentureFar Posted July 18, 2013 Posted July 18, 2013 I went to cycle gear and bought a 12 volt outlet for $10 and with just a little enlargment it fit in the hole in the plastic cover on the left side cut the little white connector off and used it to power a relay so I could use the plug for a compressor. Please post photo of your mounting. Thanks VentureFar...
etcswjoe Posted July 18, 2013 Posted July 18, 2013 Please post photo of your mounting. Thanks VentureFar... Here you go: http://www.venturerider.org/forum/showthread.php?t=72137
VentureFar Posted July 18, 2013 Posted July 18, 2013 Ah Ha! I just couldn't believe folks were cutting holes in their side covers for a power outlet. So I would go look at mine over and over and not see a factory cutout. So just now I started to take off the side cover to see if it had a detent on the inside and that is when I noticed the hole in the "filler" BEHIND the left side cover. NICE!!!
VentureFar Posted July 18, 2013 Posted July 18, 2013 Here you go: http://www.venturerider.org/forum/showthread.php?t=72137 Thanks Joe! Exactly what I needed. I was all set to go this route when I noticed the compact air compressor at cyclegear. Anyone, would you feel comfortable plugging in the cyclegear pump into your battery tender pigtail? http://www.cyclegear.com/CycleGear/Tires/Tire-Accessories/Tubes/brand/DOUBLE-TOUGH/Compact-Portable-Mini-Air-Compressor/p/43135_00000 Thanks VentureFar...
dacheedah Posted July 18, 2013 Posted July 18, 2013 thats the only place I would plug it in, right off the battery and while idling would be best
VentureFar Posted July 18, 2013 Posted July 18, 2013 thats the only place I would plug it in, right off the battery and while idling would be best won't it pull too many amps and get too hot? ie melt? VentureFar...
dacheedah Posted July 19, 2013 Posted July 19, 2013 if you are using that plug for power you should have a fuse on it for the wire size. I will say most small saddlebag air compressors have small gauge wire and should not cause a problem, on the other side it will take a bit for a fill.
etcswjoe Posted July 19, 2013 Posted July 19, 2013 Thanks Joe! Exactly what I needed. I was all set to go this route when I noticed the compact air compressor at cyclegear. Anyone, would you feel comfortable plugging in the cyclegear pump into your battery tender pigtail? http://www.cyclegear.com/CycleGear/Tires/Tire-Accessories/Tubes/brand/DOUBLE-TOUGH/Compact-Portable-Mini-Air-Compressor/p/43135_00000 Thanks VentureFar... Since it goes through a 30 amp relay to the battery I would. I know several people have cut the cigarette lighter plug off the compressor and replaced it with one that plugs into the battery tender wire that goes straight to the battery also. Either way make sure you are at least idling the compressor will pull a battery down fast.
spear Posted July 19, 2013 Posted July 19, 2013 I bought one of those three way 12V outlets with a USB outlet incorporated, and mounted it to the top of my front brake hydraulic reservoir with double-sided tape. Wrapped the lead around my bars and across to the 12V outlet in the fairing. I power my Garmin SatNav and CrashCam from the three way. Could use the USB for either of them but just doesn't pump out enough juice I'm afraid.
VentureFar Posted July 21, 2013 Posted July 21, 2013 Thanks Joe! Exactly what I needed. I was all set to go this route when I noticed the compact air compressor at cyclegear. Anyone, would you feel comfortable plugging in the cyclegear pump into your battery tender pigtail? http://www.cyclegear.com/CycleGear/Tires/Tire-Accessories/Tubes/brand/DOUBLE-TOUGH/Compact-Portable-Mini-Air-Compressor/p/43135_00000 Thanks VentureFar... Just picked up this compressor and will try it tonight I will take the seat off and run it for about 10 min-bike idling - and feel the wire to assure myself I won't burn it up. I will report. VentureFar...
VentureFar Posted July 22, 2013 Posted July 22, 2013 Bought the cyclegear pump and tried it tonight. It says that it pumps to 80 pounds and my rear Metz 880 is 50. I checked it at 47 and started the pump plugged into the charger pigtail. It ran for 10 minutes and when I took it off it had lost 8 pounds to 39. It simply couldn't do 50. So back it goes to cyclegear. I have a slim mini pump and hooked it up using a female Cigarette lighter adapter to the charger pigtail and it ran the pressure from 39 right up to 50 quicker than I expected. so the cyclegear works if you only need 35-39 pounds. If you need over that I don't suggest you buy the cyclegear.- couldn't handle over 39 for me on my Gen 2. VentureFar...
