Brake Pad Posted April 18, 2013 #1 Posted April 18, 2013 Just cause I can't remember, which Bulb do I use for the Front Blinkers? RSV 07
bongobobny Posted April 18, 2013 #2 Posted April 18, 2013 Can't remember the number either but it is a 3 prong amber bulb that you probably can only get from a dealer. You can take a regular 1157A and file one of the prongs off and it will fit...
darthandy Posted April 18, 2013 #4 Posted April 18, 2013 And as long as you're in there, don't forget to check the level of your blinker fluid. :rotf::rotf::rotf: Andy
dacheedah Posted April 19, 2013 #5 Posted April 19, 2013 if you use synthetic you should get about 50000 blinks out of that
Brake Pad Posted April 20, 2013 Author #7 Posted April 20, 2013 So, for the hex screws? Do I need one off screw driver and One On screw driver as well?:rotf:
darthandy Posted April 21, 2013 #8 Posted April 21, 2013 So, for the hex screws? Do I need one off screw driver and One On screw driver as well?:rotf: Yep! You're catching on fast. Andy
dacheedah Posted April 21, 2013 #9 Posted April 21, 2013 Hey, were south of Canada, we use one right handed and one left handed
bongobobny Posted April 21, 2013 #10 Posted April 21, 2013 Don't forget left handed and right handed monkey wrenches...
Brake Pad Posted April 21, 2013 Author #11 Posted April 21, 2013 I don't have any monkey's available:stirthepot:
Flyinfool Posted April 21, 2013 #12 Posted April 21, 2013 I don't have any monkey's available:stirthepot: Well then you will need a metric and a SAE adjustable wrench.
Brake Pad Posted April 30, 2013 Author #13 Posted April 30, 2013 I just love the wealth of information I get here for my Twelve bucks, You guys are AWESOME !!!!
djh3 Posted April 30, 2013 #14 Posted April 30, 2013 On the blinker fluid, dont you need dual action type. It works as a running light and turn signal. On a serious note about the bulbs. I remember having a conversation or two about going to LED signal bulbs. I tried it and in front didnt really work that well. But what was brought to my attention is there are some of the signal bulbs available in a longer lasting and brighter model.
