ablumny Posted April 28, 2013 Author #26 Posted April 28, 2013 I've run them at 0, 5 and 8#s. hard to imagine tire wear based on form air pressure though
Miles Posted April 28, 2013 #27 Posted April 28, 2013 I wonder if the front shock's air pressure has anything to do with tire wear? Since the bike was new, I have left the front air pressure at 0#. I just bought a zero-loss pump a few weeks ago. Now have them set at 5#, which I do like better. Of course, I have now commited the number one troubleshooting sin. I have changed two things at the same time. Tire pressure and fork pressure. So, if by chance I do get better tire mileage, I won't know for sure why. Oh well, I can live with that. Oh NO...you changed two things at once. Thta's okay, as long as it improves your tire mileage. FTIW, I run between 5 and 7 psi in the front forks of my '06 RSMTD. And, yes, you goofballs, the air pressure in your front forks does have affect on the front tire wear.
Smilerider Posted April 28, 2013 #28 Posted April 28, 2013 As I have sat and read all of these posts, I am wondering where you are getting the higher tire pressures from? Where has the 40 -41 numbers come from? I have installed an E3 on the rear and have been keeping it at the recommend pressure based on the sticker. I have been happy with the tire except in rain. It appears to hydroplane and become more slippery when wet. This has been a noticeable change over past tires.. So much more noticeable that it is a bit uncomfortable when I hit heavier rain. I have no problem adjusting the pressures to see what happens, but do you believe this will address more wet handling or make it worse? I have started to see a slight cup (very minor) to the tire and am currently at 9500 miles. I also ride solo 98% of the time(this is an issue and probably deserves is own post!!! LOL) and weight about 180lbs. I have a metzler on the front (11,000 miles) and have had odd handling since around 2500miles (again a separate issue). I have just started to look to replace the front with the E3 but the wet weather issues with the rear has me concerned. I also have 0lbs in the front forks. I should also mention that I have a sport bike as well, and on that bike i am running the tires 5-7lbs less than sticker.. This is help the stickiness and keeping the tires warmer during use. This has made a huge difference in how well it handles and how hard I can take the corners.
Smilerider Posted April 28, 2013 #29 Posted April 28, 2013 As I'm outside tinkering on the bike I thought of a couple more questions regarding the tire pressure. Are you using the 40 -41 for 2up riding as well, and is this just for the E3 tires or are you suggesting this for all tires?
