eds Posted April 14, 2013 #1 Posted April 14, 2013 Decided to start Trike and go for short ride, didn't work. Everything dead except Radio. Over the winter I installed 30 amp relay for ignition as per Carbon One's directions, also a bypass toggle. Trike started up just fine. Reassembled everything and put trickle:detective: charger back on. Today was first time back at bike and nothing. Voltage indicator shows battery is fully charged, alarm activates ,flashes lights and radio works. No dash, headlight or running lights.
GeorgeS Posted April 14, 2013 #2 Posted April 14, 2013 Most likley the Ignition switch, or maby loose battery cable. Check fuse's of course. Take a look at Main Fuses, first. Pull tank, open the two plugs from the Ignition switch, and do a resistance check thru the On - Off contacts. Bad contacts in the switch are very common. There is a fix for this, but it takes some work, or a new switch
eds Posted April 15, 2013 Author #3 Posted April 15, 2013 OK! All is good. Went back through and reread Carbon One's posting again. I had two wires switched on the relay. Corrected and all is good.
