alvald83 Posted April 14, 2013 #1 Posted April 14, 2013 I have an '83 Venture and need to remove the rectifier. Any tricks?
dingy Posted April 14, 2013 #2 Posted April 14, 2013 1st picture is what it looks like from the rear of bike with rear end removed. 2nd is from left side looking forward. 3rd left looking rear. 2 mounting screws, from outside of left frame thru to R/R. Gary
Snaggletooth Posted April 14, 2013 #4 Posted April 14, 2013 I don't know what your game plan is but I'm gonna share a quick story. I removed my OEM R/R and replaced it with an aftermarket unit. Little different mounting in the original position and a bit tighter fit. I had replaced the OEM exhaust with MAC turndowns just prior to that. So the the end results weren't pretty. I had it a bit too close to the pipes. Those little suckers deal with enough heat without the pipes adding to it. After that I installed the Shindengen in the fairing.
Peder_y2k Posted April 14, 2013 #5 Posted April 14, 2013 A littl off -topic, but when I saw how close the R/R was to the exhaust, I fabricated and installed a sheet metal heat shield to minimize radiant heat gain from the close proximity pipe. Seems to function adequately. -Pete, in Tacoma WA USA '83,88
reddevilmedic Posted April 14, 2013 #6 Posted April 14, 2013 I mounted the Shindigen up front, off the radiator cover. it gets plenty off air.....
