1st picture is what it looks like from the rear of bike with rear end removed.
2nd is from left side looking forward.
3rd left looking rear.
2 mounting screws, from outside of left frame thru to R/R.
Gary
I don't know what your game plan is but I'm gonna share a quick story. I removed my OEM R/R and replaced it with an aftermarket unit. Little different mounting in the original position and a bit tighter fit. I had replaced the OEM exhaust with MAC turndowns just prior to that.
So the the end results weren't pretty. I had it a bit too close to the pipes. Those little suckers deal with enough heat without the pipes adding to it.
After that I installed the Shindengen in the fairing.
A littl off -topic, but when I saw how close the R/R was to the exhaust, I fabricated and installed a sheet metal heat shield to minimize radiant heat gain from the close proximity pipe.
Seems to function adequately.
-Pete, in Tacoma WA USA
'83,88
