  • Replies 148
  • Created
  • Last Reply
Top Posters In This Topic
  Freebird said:
OK...please try again.
...I can see that you are listed...BTW what's the difference between "registered" and "supporting"?:think:
Basically "registered" are trial members. I've removed that one. If we use this the way I am envisioning it, it will primarily be our "assistance list". Only supporting members will have access to that information. Telephone numbers and etc.
Guest tx2sturgis
Hmmmm...the entire map comes up but it only shows the one marker for Freebird...no other markers...is this a test mode or should there be other markers visible?
  Aussie Annie said:
:crying::crying::crying:
Where's the big island down under??
thats cause we dont want you to go back so now you and quick step have to stay :whistling::confused24::confused24:
Same here, once I set a marker , leave and come back later the marker is gone.
Is there a window zoom function that i missed, it is a little clumsy getting down to the street level, doable, but clumsy without a window zoom.
Eileen is used to it. :)
OK....I just took a look and I think I figured it out. A couple of things. I had it set so that I had to approve the entries. I now have it set to auto-improve. I also had to set a cron job so it may be that your information won't show immediately. I have the cron job set to run every 10 minutes.
Those of you who have already entered your information are showing now.
I just made it a sticky but once I determine that it's going to work out OK, and that people like it, I'll add a link to it from the left menu or the upper menu bar.
