Pappa Bear Posted February 9, 2008 #1 Posted February 9, 2008 when you sync the carbs which screw do ya turn to do the adjusting and which hose do ya connect to for the gauges. I am a newbe, never done it before but I want to learn. thanks ( for a 89 VR non california )
Rocket Posted February 9, 2008 #2 Posted February 9, 2008 when you sync the carbs which screw do ya turn to do the adjusting and which hose do ya connect to for the gauges. I am a newbe, never done it before but I want to learn. thanks ( for a 89 VR non california ) Info in the tech library, see this link http://www.venturerider.org/forum/showthread.php?t=495
Pappa Bear Posted February 10, 2008 Author #3 Posted February 10, 2008 thank you, that makes it so much easier, best regards , Ron:banana:
