Venturous Randy Posted April 13, 2013 #51 Posted April 13, 2013 I have a throttle lock and the palm thing and both work very well for me. I keep the throttle lock tight enough to hold the throttle in position, but still loose enough that I can make small adjustments without unlatching it. I have foam grips and have had a problem with the palm thing slipping a little. I started using the old double sided sticky electrical tape that has a cloth base under it and it works well. I am dealing with carpel tunnel and pretty bad neuropathy in my right hand and would have a hard time riding without these things, especially with my bike being a standard without cruise control. RandyA
Guest tx2sturgis Posted April 13, 2013 #52 Posted April 13, 2013 (edited) Here are the pics of the crampbuster on the Ural. Miles, if this isnt to your liking, then maybe someone else can use the idea. First pic shows the crampbuster in normal position. Second pic shows it rolled around under the grip. Third pic shows the tip of the 'blade' resting on the brake lever with the throttle rolled back (use the seam on the grip base for reference) ...yes, it takes two hands, or deft movement of the right thumb, to do this. Fourth pic shows me rolling the throttle forward, (reducing throttle) and the tip of the blade will gently slide past the brake lever. I dont know if this will work on the anyone else’s bike or not, but it works on this one. Edited April 14, 2013 by tx2sturgis
Miles Posted April 14, 2013 Author #53 Posted April 14, 2013 Here are the pics of the crampbuster on the Ural. Miles, if this isnt to your liking, then maybe someone else can use the idea. Brian, thank you, but I do have several, of those and others in my shop. I do use them, but for the long ride bikes I use the Kuryakyn Iso-grip throttle boss...the larger one. Thanks,
