Did you install your own hitch or paid to have it installed ? Not sure if I should buy the hitch and swivel ball and install it myself or go to my local Yamaha dealer here in St. Petersburg (Barney's) and pay $475 for hitch, ball and labor !
(RSV '07)
Installed my own. For 1st gen bought one on Fleabay and bolted it up. On 2nd gen bought one from Diamond R, a hide a hitch, and 4 bolts later it was installed. On trike I let Hannigan do it only because I felt lazy...
$475 is pretty steep for a hitch.
They quoted me $250 for hitch and ball + 2 hours of labor ($90/hr) ... I found it steep in parts and length of labor time.
I asked my brother in Montreal to get a quote, they came back with $500 + tax = $580.00 for the whole thing, parts and labor
There really is nothing to this project. I built my own, installed, and wire for trailer. It is a simple job. To just install hitch maybe 20 min. To wire the bike and run the wire like you want maybe 45 if take time and know the wires you need to attach to.
Buy from Larry and do it yourself or ask around for a close by VR.org member to help.
If I was close by I would help.
Doing the hitch yourself is a piece of cake. It'll take longer to install the trailer pigtail...but not difficult...
trailer pigtail will do it myself !! They'd charge me 1 more hour !! lol
Edited by AngryAmish
There is a guy on this site that sells a plug and play for the venture for the trailer wiring, For the life of me I can't think of his name. I am sure someone on here will help refresh my memory.
If using my hitch you remove four 5/16" sized (metrics thou) bolts , pull off the cross bar, insert the hitch, and replace the bolts. It's that simple & probably takes 15-20 minutes at most.
http://www.venturerider.org/classifieds/showproduct.php?product=3919&title=rsv26amp-3b-rstd-trailer-hitch&cat=24
Larry
Hi Larry , for the extension, I guess I can get it anywhere like HF or other places like that !
m61a1mech or something like that, from Florida if I'm not mistaken.
Edited by jonesy
spelling
i built my own and installed it my self not hard at all, course then i never bought a trailer so i never used it. although my yamaha dealer had to remove it to replace my back tire and they would not put it back on due to liability issues is what they told me.:confused24:
Did it myself.
Pulled the entire rig from my 1st gen parts bike. I had it in a storage bin for about a year. I did buy a new wiring kit for the lights since my trailer is 2 lights & the bikes have independent turn signals
The only change I did was add a swivel ball to the hitch.
All things considered, it was a very easy install.
Do the hardware yourself. Just bolts. No jack, no torque, no brainer.
And then if you need help on the wiring, maybe Steve K,,, who happens to make the harness on this site, can help. M61A1MECH
His Member/Vendor ad: http://www.venturerider.org/classifieds/showproduct.php?product=4200&title=auxillary-tail-light-harness-for-royal-star-venture&cat=35
He lives in Edgewater, FL. Just shoot across on I-4
Edited by Mike G in SC
Same here made my own from small car hitch(cut it down to fit)
Made my own wiring patch also since I needed it right away to go to maintenance day last year or I would have bought them from the members on sight.
Also dealer wouldn't install because of liability issues .
Usually takes 1/2 hour to remove saddle bags,hitch and disconnect harness then put in original spacer so I can take in for dealer service then change back when I get it home.
They know I tow a trailer as I showed up a few times with bike I traded in(2000 Road-star) to buy 2012 Venture.
hitchdoc hitches are hard to put on, I had to have a friend help me, we had to support the trunk by tying it to the rafters, tighten the bolts from left to right, not one side at a time, the fender will look crooked
AngryAmish I would be glad to help if you need it, most hitch set ups for the Ventures only require that you remove the spanner section that connects the left and right saddlebag supports and replace it with the hitch, mine is 4 bolts. I do have harnesses available, I would suggest using a isolator for the trailer, that will keep the added electrical off of the bike's harness, if the trailer has LEDs you could do without the isolator. Also if your trailer is wired for a four wire set up you will need a convertor to go from the blke's five wire system to the trailer's four wire system, both the isolator and the convertor can be found at Electrical Connection. http://www.electricalconnection.com/wire-harnesses/hrns-trailer.htm
Call me or email me , my contact info is in my profile.
I may just do that Steve. I know you are not too far from NSB. I can stop by on my way on my trip north. I will call/email you weeks before I head up in mid-May. Thank you Steve :)
Armando
