Center Stand
MongoE9
I bought a center stand from Ponch last year and it has worked great. Unfortunately the kick stand part bent so now it won't work. I have sent Ponch a couple of messages, but no reply. Anyone have any other ideas about a center stand without having to pay $300 for it? Thanks
Mongo
I'm pretty sure that he patterned them after the ones that I was making. He had asked me if it was OK. If so, it is just a stand off a first gen. You should be able to pick one up off ebay for less than $20.00. Will be easy to make the few changes to hook it to the special bracket.
I didn't use those parts on the second gen conversion. I usually got those pieces when I bought the used stands and I think I threw them all away a while back. Probably had a hundred of them. I'll look when I get home to see if I still have one laying around somewhere.
Ok, I have a center stand and after looking at it was trying to figure out a different way to mount it up, I do miss that from my first gen. I helpped a harley buddy put one on his bike and it was attached to a plate that clamped to the frame with like 3/8 steel. Other projects going but one I want to finish.
If you haven't seen them, here are the instructions and dimensions of the bracket that I was making.
http://www.venturerider.org/forum/showthread.php?t=1427
I have seen that, my thought was I could attach it to a plate clamped to the lower frame and leave the holes under the center for my lift adapter. I never looked to see how far back and how it was attached to the first gen. I might need pictures. . .
  • 2 weeks later...
It is the life arm that is bent. I did bend it back to shape, but the next time I tried to get it under my bike it just bent again. I am sure it was weakend due to the angle when I had a rear blow out on the freeway doing 70. I am sure these things were not designed to lift the bike when the back tire is flat. Lately I have just been going back to the 2x4 under the tire and it works then. Now I just have to figure out why my brand new Avon Venom is leaking air. Spray bottle up! Thanks all.
Mongo
