AngryAmish Posted March 16, 2013 Posted March 16, 2013 Hi. I have a question regarding an installation of an XM/Sirius radio. I do have the unit, cradle and cables. I am not worried about brackets, because on the board here I see how the members' mount them up. Shouldn't be a problem. On the cradle there are 3 inputs/outputs, one says DC in which I hook into a cigarette lighter socket. Other one is Ant in, which is the antenna, no problem there, my issue is the Audio out ? Do I connect that cable to the input beside the cassette deck ? (Royal Star Venture '07) or somewhere else ? Thanks
Guest tx2sturgis Posted March 17, 2013 Posted March 17, 2013 You can do it that way, but you might get some unwanted noise, and/or, the audio might be low. I've had good luck using the cassette adapter unit that comes with some of the XM radios, or used to. You can also buy them pretty cheap on ebay and amazon.
ragtop69gs Posted March 17, 2013 Posted March 17, 2013 I opened the fairing and put a splitter in the line behind the cassette and plugged in the output there. Doing it that way you don't have to have the cassette door open all the time.
cecdoo Posted March 17, 2013 Posted March 17, 2013 I opened the fairing and put a splitter in the line behind the cassette and plugged in the output there. Doing it that way you don't have to have the cassette door open all the time. :sign yeah that::sign yeah that::sign yeah that:
Rick Haywood Posted March 17, 2013 Posted March 17, 2013 I opened the fairing and put a splitter in the line behind the cassette and plugged in the output there. Doing it that way you don't have to have the cassette door open all the time. :sign yeah that::sign yeah that:
Guest tx2sturgis Posted March 18, 2013 Posted March 18, 2013 I opened the fairing and put a splitter in the line behind the cassette and plugged in the output there. Doing it that way you don't have to have the cassette door open all the time. Just FYI...my cassette door is not 'open all the time'...
AngryAmish Posted March 19, 2013 Author Posted March 19, 2013 Just FYI...my cassette door is not 'open all the time'... You can close door with cable coming out ?
