Have a 1984 royal that has all of a sudden developed a noise that I can not find, When you put into gear and give any throttle heare a ratcheting sound , first i thought it was the splines on the inner clutch hub , tore down and is ok, sounded like it was there , does it in all gears, any ideas would be greatley appreciated. NASCAR0699
It very well could be the splines at the differential end of the driveshaft. Not the driveshaft itself but the splined sleeve whatchamacallit the driveshaft goes into.
Called the "coupling gear"
Part #10 in the pic
Start watching E-Bay for a new pumpkin, and maby drive shaft assembly. How many miles on this bike ?
Is this noise just noticiable at, say, 40 mph. Or is it really loud ??
If the latter, I think I would pull the pumpkin and drive shaft now, and see what you find. Instead of waiting for the next tire change.
SOmetyhing l;ike this happened to me. I took off the swing arm and looked into the middle gear. I saw something had split in half. It woild astill move but barely. There is a part called the driven cam. I had to split the crank case to repair.
